On local ISS of nonlinear second-order time-delay systems without damping † - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2024
Emilia Fridman
  • Fonction : Auteur
  • PersonId : 838164
For a second-order system with vector position, either constant or time-varying delays, and a power nonlinearity of the degree higher than one, which does not contain a velocity-proportional damping term, the conditions of local input-to-state stability are proposed. The result is based on application of Lyapunov-Razumikhin approach, for which new time estimates on decay of solutions are obtained. The approach is extended to attitude stabilization of a rigid body, and it is illustrated by simulations.
Automatique
dom-3-full.pdf (659.45 Ko) Télécharger le fichier
hal-04396969 , version 1 (16-01-2024)
Paternité
  • HAL Id : hal-04396969 , version 1
Alexander Aleksandrov, Denis Efimov, Emilia Fridman. On local ISS of nonlinear second-order time-delay systems without damping †. International Journal of Robust and Nonlinear Control, In press. ⟨hal-04396969⟩
24 Consultations
49 Téléchargements
