Controllable motion lines generation for an abstracted depiction of 3D motion. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Based on a user input motion hierarchy (left), our method allows the artist to generate motion lines depicting sub-motions. Here, we show two types of motion lines, generated from the same input animation depicting the translation (middle) or the rotation (right) of a spinning top.
Controllable motion lines generation for an abstracted depiction of 3D motion.pdf.pdf (5.25 Mo) Télécharger le fichier
hal-04397569 , version 1 (16-01-2024)
Paternité
  • HAL Id : hal-04397569 , version 1
Mohamed-Amine Farhat, Alexandre Bléron, Camille Noûs, Romain Vergne, Joëlle Thollot. Controllable motion lines generation for an abstracted depiction of 3D motion.. J.FIG 2023 - journées Françaises de l'Informatique Graphique, AFIG, Nov 2023, Montpellier, France. pp.1-5. ⟨hal-04397569⟩
17 Consultations
10 Téléchargements
