The Two-Point Finite Volume Scheme for the Microscopic Bidomain Model of Electrocardiology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We are interested in the approximation of a cardiac microscopic model. It is a set of Laplace equations with non-standard, timedependent, transmission conditions, for which finite volume methods are of real interest. The transmission conditions state as ordinary differential equations on the jump of the potential, namely the transmembrane voltage, so that we keep this voltage as an unknown in our scheme. Here we extend the two-point flux approximation to the discretization of this model, show that it converges, and compute error estimates.
last_version_fvca10_zeina.pdf (329.25 Ko) Télécharger le fichier
hal-04403881 , version 1 (18-01-2024)
Paternité
  • HAL Id : hal-04403881 , version 1
Zeina Chehade, Yves Coudière. The Two-Point Finite Volume Scheme for the Microscopic Bidomain Model of Electrocardiology. FVCA 10 - Finite Volume for Complex applications 10, Oct 2023, Strasbourg, France. ⟨hal-04403881⟩
8 Consultations
11 Téléchargements
