Bayesian Optimization of Light Grating for High Performance Single-Photon Avalanche Diodes
Bayesian optimization is used to investigate the optimal grating parameters of realistic SPADs, enhancing high absorption by positioning a resonance exactly at 940 nm. Bayesian optimization allows us to find optimal parameters while minimizing the numerical cost required.
