Bayesian Likelihood Free Inference using Mixtures of Experts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
We extend Bayesian Synthetic Likelihood (BSL) methods to non-Gaussian approximations of the likelihood function. In this setting, we introduce Mixtures of Experts (MoEs), a class of neural network models, as surrogate likelihoods that exhibit desirable approximation theoretic properties. Moreover, MoEs can be estimated using Expectation-Maximization algorithm-based approaches, such as the Gaussian Locally Linear Mapping model estimators that we implement. Further, we provide theoretical evidence towards the ability of our procedure to estimate and approximate a wide range of likelihood functions. Through simulations, we demonstrate the superiority of our approach over existing BSL variants in terms of both posterior approximation accuracy and computational efficiency.
soumis-main0.pdf (1.31 Mo) Télécharger le fichier
hal-04436187 , version 1 (03-02-2024)
Paternité
  • HAL Id : hal-04436187 , version 1
Florence Forbes, Hien Duy Nguyen, Trungtin Nguyen. Bayesian Likelihood Free Inference using Mixtures of Experts. 2024. ⟨hal-04436187⟩
75 Consultations
64 Téléchargements
