Weights for moments' geometrical localization: a canonical isomorphism - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
This paper deals with high order Whitney forms. We define a canonical isomorphism between two sets of degrees of freedom. This allows to geometrically localize the classical degrees of freedom, the moments, over the elements of a simplicial mesh. With such a localisation, it is thus possible to associate, even with moments, a graph structure relating a field with its potential.
ACDR_isom.pdf (945.93 Ko) Télécharger le fichier
hal-04443059 , version 1 (07-02-2024)
  • HAL Id : hal-04443059 , version 1
Ana Alonso Rodríguez, Jessika Camaño, Eduardo de Los Santos, Francesca Rapetti. Weights for moments' geometrical localization: a canonical isomorphism. 2023. ⟨hal-04443059⟩
40 Consultations
10 Téléchargements
