Multi-Level GNN Preconditioner for Solving Large Scale Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
Large-scale numerical simulations often come at the expense of daunting computations. High-Performance Computing has enhanced the process, but adapting legacy codes to leverage parallel GPU computations remains challenging. Meanwhile, Machine Learning models can harness GPU computations effectively but often struggle with generalization and accuracy. Graph Neural Networks (GNNs), in particular, are great for learning from unstructured data like meshes but are often limited to small-scale problems. Moreover, the capabilities of the trained model usually restrict the accuracy of the data-driven solution. To benefit from both worlds, this paper introduces a novel preconditioner integrating a GNN model within a multi-level Domain Decomposition framework. The proposed GNN-based preconditioner is used to enhance the efficiency of a Krylov method, resulting in a hybrid solver that can converge with any desired level of accuracy. The efficiency of the Krylov method greatly benefits from the GNN preconditioner, which is adaptable to meshes of any size and shape, is executed on GPUs, and features a multi-level approach to enforce the scalability of the entire process. Several experiments are conducted to validate the numerical behavior of the hybrid solver, and an in-depth analysis of its performance is proposed to assess its competitiveness against a C++ legacy solver.
main.pdf (4.43 Mo) Télécharger le fichier
hal-04447099 , version 1 (12-02-2024)
Paternité
  • HAL Id : hal-04447099 , version 1
Matthieu Nastorg, Jean-Marc Gratien, Thibault Faney, Michele Alessandro Bucci, Guillaume Charpiat, et al.. Multi-Level GNN Preconditioner for Solving Large Scale Problems. 2024. ⟨hal-04447099⟩
51 Consultations
22 Téléchargements
