Aerosolomics based approach to discover source molecular markers: A case study for discriminating residential wood heating vs garden green waste burning emission sources - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Chemosphere Année : 2024
Biomass burning is a significant source of particulate matter (PM) in ambient air and its accurate source apportionment is a major concern for air quality. The discrimination between residential wood heating (RWH) and garden green waste burning (GWB) particulate matter (PM) is rarely achieved. The objective of this work was to evaluate the potential of non-targeted screening (NTS) analyses using HRMS (high resolution mass spectrometry) data to reveal discriminating potential molecular markers of both sources. Two residential wood combustion appliances (wood log stove and fireplace) were tested under different output conditions and wood moisture content. GWB experiments were carried out using two burning materials (fallen leaves and hedge trimming). PM samples were characterized using NTS approaches with both LC- and GC-HRMS (liquid and gas chromatography-HRMS). The analytical procedures were optimized to detect as many species as possible. Chemical fingerprints obtained were compared combining several multivariate statistical analyses (PCA, HCAand PLS-DA). Results showed a strong impact of the fuel nature and the combustion quality on the chemical fingerprints. 31 and 4 possible markers were discovered as characteristic of GWB and RWH, respectively. Complementary work was attempted to identify potential molecular formulas of the different potential marker candidates. The combination of HRMS NTS chemical characterization with multivariate statistical analyses shows promise for uncovering organic aerosol fingerprinting and discovering potential PM source markers.
2024-003.pdf (5.07 Mo) Télécharger le fichier
Origine : Publication financée par une institution
Licence : CC BY NC - Paternité - Pas d'utilisation commerciale
hal-04449562 , version 1 (21-03-2024)
Camille Noblet, François Lestremau, Serge Collet, Claudine Chatellier, Jérôme Beaumont, et al.. Aerosolomics based approach to discover source molecular markers: A case study for discriminating residential wood heating vs garden green waste burning emission sources. Chemosphere, 2024, 352, pp.141242. ⟨10.1016/j.chemosphere.2024.141242⟩. ⟨hal-04449562⟩
48 Consultations
0 Téléchargements
