The effect of granulometry of carbonaceous materials and application rates on the availability of soil-bound Dichlorodiphenyltrichloroethane (DDT) and its metabolites - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Xenobiotics Année : 2024
Biochars (BCs) and activated carbons (ACs) are well-known carbon-rich materials that are being increasingly studied in environmental sciences for water treatment applications to remediate pollutant sequestration in soil. This study aimed to assess the impact of Sargasso BC particle size and amendment rate on the environmental availability of DDT and DDT metabolites in two distinct Kazakh soils. These two soils were collected in the vicinity of storehouse facilities in Kyzylkairat and Beskainar that store banned pesticides. They presented very distinct concentration levels of DDT and DDT metabolites. Three different types of carbonaceous matrices were tested: Sargasso BC and two commercial ACs (ORBO TM and DARCO ©). For the granulometry effect, Sargasso BC was ground, and two particle sizes were tested (<150 µm, >150 µm) and compared to an unground material. Four distinct application rates were tested (0.25, 0.5, 1, and 2% (w/w)). After a threemonth maturation period, environmental availability was assessed using an ISO/DIS 16751, part B-modified methodology. Interestingly, the best reductions in DDT environmental availability were obtained with the finest particle size (both ACs and Sargasso BC < 150 µm). More specifically, the effectiveness of the strategy seemed to depend on many factors. Firstly, a clear soil effect was demonstrated, suggesting that the more contaminated the soil, the more efficient this strategy may be. Secondly, the results showed that an increase in the amendment rate improves the immobilization of DDT and DDT metabolites. The sequestration material demonstrated different efficiency values (up to 58 ± 4% for Sargasso BC < 150 µm and 85 ± 4% for DARCO at a 2% application rate). Finally, a clear molecule effect was displayed, demonstrating the following immobilization order: p,p'-DDE > p,p'-DDD > p,p'-DDT > o,p'-DDT.
jox-14-00016.pdf (2.09 Mo) Télécharger le fichier
Origine : Publication financée par une institution
Licence : CC BY - Paternité
hal-04451309 , version 1 (11-02-2024)
Paternité
Farida Amutova, Ronagul Turganova, Gaukhar Konuspaye, Sarra Gaspard, Aigerim Mamirova, et al.. The effect of granulometry of carbonaceous materials and application rates on the availability of soil-bound Dichlorodiphenyltrichloroethane (DDT) and its metabolites. Journal of Xenobiotics, 2024, 14, pp.267-284. ⟨10.3390/jox14010016⟩. ⟨hal-04451309⟩
40 Consultations
16 Téléchargements
