Next Generation Vehicles, Safety, and Cybersecurity—The CMX Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Intelligent Transportation Systems Année : 2024
Jonathan Petit
  • Fonction : Auteur
  • PersonId : 1351149
  • IdRef : 164096965
Gérard Le Lann
Safety, privacy, efficiency and cybersecurity (SPEC) properties are mandatory in vehicular networks. Owing to intrinsic limitations, the V2X framework and related communicating autonomous vehicles are inadequate. We explore the CMX framework (Coordinated Mobility for X = SPEC), Next Generation Vehicles (NGVs), and protocols for safety-critical inter-vehicle communications and agreements that solve problems left open in the V2X framework. Then, we focus on cyberattacks and physical attacks against isolated NGVs and cohorts of NGVs. The cyberphysical security analysis investigates more than 20 attacks and demonstrates that the goal set for CMX is verified. In the presence of attacks, safety is never compromised, possibly at the expense of diminished efficiency.
CMX_Security-IEEE Tr-ITS 2024.pdf (497.9 Ko) Télécharger le fichier
hal-04453750 , version 1 (12-02-2024)
Paternité
Jonathan Petit, Gérard Le Lann. Next Generation Vehicles, Safety, and Cybersecurity—The CMX Framework. IEEE Transactions on Intelligent Transportation Systems, 2024, 25 (2), pp.1333-1345. ⟨10.1109/TITS.2023.3318376⟩. ⟨hal-04453750⟩
Collections
INRIA INRIA2
40 Consultations
34 Téléchargements
