Learning Optimal Policies in Mean Field Models with Kullback-Leibler Regularization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The theory and application of mean field games has grown significantly since its origins less than two decades ago. This paper considers a special class in which the game is cooperative, and the cost includes a control penalty defined by Kullback-Leibler divergence, as commonly used in reinforcement learning and other fields. Its use as a control cost or regularizer is often preferred because this leads to an attractive solution. This paper considers a particular control paradigm called Kullback-Leibler Quadratic (KLQ) optimal control, and arrives at the following conclusions: 1. in application to distributed control of electric loads, a new modeling technique is introduced to obtain a simple Markov model for each load (the ‘agent’ in mean field theory). 2. It is argued that the optimality equations may be solved using Monte-Carlo techniques—a specialized version of stochastic gradient descent (SGD). 3. The use of averaging minimizes the asymptotic covariance in the SGD algorithm; the form of the optimal covariance is identified for the first time.
Fichier non déposé
hal-04476983 , version 1 (26-02-2024)
Paternité
Ana Bušić, Sean Meyn, Neil Cammardella. Learning Optimal Policies in Mean Field Models with Kullback-Leibler Regularization. 2023 62nd IEEE Conference on Decision and Control (CDC), Dec 2023, Singapore, Singapore. pp.38-45, ⟨10.1109/CDC49753.2023.10383868⟩. ⟨hal-04476983⟩
48 Consultations
0 Téléchargements
