Inertial line-of-sight stabilization using a 3-dof spherical parallel manipulator with coaxial input shafts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
This article dives into the use of a 3-RRR Spherical Parallel Manipulator (SPM) for the purpose of inertial Line Of Sight (LOS) stabilization. Such a parallel robot provides three Degrees of Freedom (DOF) in orientation and is studied from the kinematic point of view. In particular, one guarantees that the singular loci (with the resulting numerical instabilitiesand inappropriate behavior of the mechanism) are far away from the prescribed workspace. Once the kinematics of the device is certified, a control strategy needs to be implemented in order to stabilize the LOS through the upper platform of the mechanism. Such a work is done with MATLAB Simulink® using a SimMechanics™ model of our robot.
OPTRO2024_37_A. LE_P.pdf (1.63 Mo) Télécharger le fichier
hal-04483255 , version 1 (29-02-2024)
Paternité
  • HAL Id : hal-04483255 , version 1
Alexandre Lê, Guillaume Rance, Fabrice Rouillier, Damien Chablat. Inertial line-of-sight stabilization using a 3-dof spherical parallel manipulator with coaxial input shafts. OPTRO2024 - 11th International Symposium on Optronics in defence & security, Jan 2024, Bordeaux, France. ⟨hal-04483255⟩
38 Consultations
7 Téléchargements
