Density-Based Semantics for Reactive Probabilistic Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Synchronous languages are now a standard industry tool for critical embedded systems. Designers write high-level specifications by composing streams of values using block diagrams. These languages have been extended with Bayesian reasoning to program state-space models which compute a stream of distributions given a stream of observations. However, the semantics of probabilistic models is only defined for scheduled equations-a significant limitation compared to dataflow synchronous languages and block diagrams which do not require any ordering. In this paper we propose two schedule agnostic semantics for a probabilistic synchronous language. The key idea is to interpret probabilistic expressions as a stream of un-normalized density functions which maps random variable values to a result and positive score. The co-iterative semantics interprets programs as state machines and equations are computed using a fixpoint operator. The relational semantics directly manipulates streams and is thus a better fit to reason about program equivalence. We use the relational semantics to prove the correctness of a program transformation required to run an optimized inference algorithm for state-space models with constant parameters.
2308.01676.pdf (3.77 Mo) Télécharger le fichier
hal-04488216 , version 1 (04-03-2024)
Guillaume Baudart, Louis Mandel, Christine Tasson. Density-Based Semantics for Reactive Probabilistic Programming. 2024. ⟨hal-04488216⟩
15 Consultations
5 Téléchargements
