Controllable virtual network service over a multiadministrative multi-domain network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
In this paper, we propose a controllable virtual network service that can be provided on a multi-administrative multi-domain network. A resource allocation algorithm is proposed to compute the resources from different domains that are needed to support the virtual network with the required QoS. An implementation of the service on an OpenFlow enabled multi-domain network is described. The service is then applied in the context of coalition military network to show its benefits and potential.
Controllable_virtual_network_service_over_a_multi_administrative_multi_domain_network___public.pdf (1.73 Mo) Télécharger le fichier
hal-04502334 , version 1 (13-03-2024)
hal-04502334 , version 2 (15-04-2024)
  • HAL Id : hal-04502334 , version 2
Stanislas Pedebearn, Slim Abdellatif, Pascal Berthou, Dariusz Nogalski, Dallal Belabed. Controllable virtual network service over a multiadministrative multi-domain network. 27th IEEE International Symposium On Real-Time Distributed Computing (ISORC 2024), May 2024, Carthage, Tunis, Tunisia. à paraître. ⟨hal-04502334v2⟩
27 Consultations
7 Téléchargements
