Utilizing Fine Marine Sediment as a Partial Substitute for Sand in Self-Compacting Concrete Specially Designed for Application in Marine Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Sustainability Année : 2024
The disposal of marine sediments poses a significant economic and environmental challenge on a global scale. To address this issue and promote resource optimization within a circular-economy paradigm, this research investigates the viability of incorporating untreated fine marine sediments as a partial replacement for sand in self-compacting concrete (SCC) designed especially for application in marine environments (an exposure class of XS2 and a resistance class of C30/37 according to standard NF EN 206). The concretes mis-design incorporating 30% by weight of sediment as a sand substitute was initially designed with the modified Dreux–Gorisse method. The findings indicate that it is feasible to design an SCC suitable for marine environments, incorporating 30% sediment replacement content and without significantly compromising concrete properties, durability, or the estimated lifespan of the formulated concretes. The integration of marine sediment as a sand substitute into the SCC mix design reduces the amount of binder and limestone filler without compromising the paste volume. This results in a significant saving of natural sand resources and a reduction in CO2 emissions for SCC made with marine sediment.
sustainability-16-02538-1.pdf (3.52 Mo) Télécharger le fichier
Licence : CC BY - Paternité
hal-04512521 , version 1 (20-03-2024)
Mahmoud Hayek, Tara Soleimani, Marie Salgues, Jean-Claude Souche. Utilizing Fine Marine Sediment as a Partial Substitute for Sand in Self-Compacting Concrete Specially Designed for Application in Marine Environments. Sustainability, 2024, 16 (6), pp.2538. ⟨10.3390/su16062538⟩. ⟨hal-04512521⟩
13 Consultations
1 Téléchargements
