Warming effects on lizard gut microbiome depend on habitat connectivity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the Royal Society B: Biological Sciences Année : 2024
Climate warming and landscape fragmentation are both factors well known to threaten biodiversity and to generate species responses and adaptation. However, the impact of warming and fragmentation interplay on organismal responses remains largely under-explored, especially when it comes to gut symbionts, which may play a key role in essential host functions and traits by extending its functional and genetic repertoire. Here, we experimentally examined the combined effects of climate warming and habitat connectivity on the gut bacterial communities of the common lizard ( Zootoca vivipara ) over three years. While the strength of effects varied over the years, we found that a 2°C warmer climate decreases lizard gut microbiome diversity in isolated habitats. However, enabling connectivity among habitats with warmer and cooler climates offset or even reversed warming effects. The warming effects and the association between host dispersal behaviour and microbiome diversity appear to be a potential driver of this interplay. This study suggests that preserving habitat connectivity will play a key role in mitigating climate change impacts, including the diversity of the gut microbiome, and calls for more studies combining multiple anthropogenic stressors when predicting the persistence of species and communities through global changes.
Fromm et al 2024-accepted version.pdf (1.11 Mo) Télécharger le fichier
hal-04558931 , version 1 (25-04-2024)
Emma Fromm, Lucie Zinger, Félix Pellerin, Lucie Di Gesu, Staffan Jacob, et al.. Warming effects on lizard gut microbiome depend on habitat connectivity. Proceedings of the Royal Society B: Biological Sciences, 2024, 291 (2021), pp.20240220. ⟨10.1098/rspb.2024.0220⟩. ⟨hal-04558931⟩
0 Consultations
0 Téléchargements
