Heavy halogen impact on Raman water bands at high pressure: Implications for salinity estimations in fluid inclusions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Chemical Geology Année : 2024
We present a new experimental dataset on the impact of the heavy halogens chlorine, bromine and iodine on the Raman water bands concerning pressure and their concentration at room temperature. These experiments were conducted at ambient temperature, with variations in halogen concentration and pressure ranging from 0 to 1.4 GPa. The strength of the Raman water band shift change increases with the ionic size from chlorine, over bromine, to iodine. Our experiments further demonstrate that increased pressure diminishes the impact of the halogen shift change to a varying extent for each of the three halogens. This finding can have significant implications for the salinity calculation of fluid inclusions in minerals such as quartz or olivine. Particularly in the low salinity range, the concentration can be markedly underestimated if the pressure effect is neglected. For experiments in diamond anvil cells involving halogens dissolved in water, the change in Raman water band shifts can serve either as a new tool to monitor pressure, or to monitor the salinity.
CHEMGE16700_depot.pdf (2.18 Mo) Télécharger le fichier
hal-04560527 , version 1 (26-04-2024)
Tobias Grützner, Hélène Bureau. Heavy halogen impact on Raman water bands at high pressure: Implications for salinity estimations in fluid inclusions. Chemical Geology, 2024, 654, pp.122065. ⟨10.1016/j.chemgeo.2024.122065⟩. ⟨hal-04560527⟩
0 Consultations
0 Téléchargements
