Influence of the LiNi0.6Mn0.2Co0.2O2 (NMC 622) layered oxide morphology on the positive electrode/electrolyte interface - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Erwan Dumont
  • Fonction : Auteur
Lucille Gal
  • Fonction : Auteur
The LiNi0.6Mn0.2Co0.2O2 layered oxide is a very attractive positive electrode material for Li-ion batteries and possibly in a near future for all-solid-state batteries, thanks to good capacity, stability and cyclability upon long range cycling in the former1,2...
Matériaux
SoloyA_GFECI_2021.pdf (1.08 Mo) Télécharger le fichier
hal-04566633 , version 1 (02-05-2024)
  • HAL Id : hal-04566633 , version 1
Adrien Soloy, Delphine Flahaut, Joachim Allouche, Dominique Foix, Germain Salvato Vallverdu, et al.. Influence of the LiNi0.6Mn0.2Co0.2O2 (NMC 622) layered oxide morphology on the positive electrode/electrolyte interface. Groupe Français d'Étude des Composés d'Insertion - GFECI 2021, Groupe Français d'Étude des Composés d'Insertion, Mar 2021, Visioconférence, France. ⟨hal-04566633⟩
0 Consultations
0 Téléchargements
