Redesigning arable farming systems to encourage the spread of biosolutions
Reconception des systèmes de grandes cultures pour favoriser la diffusion des biosolutions
Biosolutions, which include biocontrol solutions, biostimulants and biofertilizers, are considered as levers of interest to help with the agroecological transition of farming systems and to improve their resilience in the face of climate change. However, a number of technical and socio-economical gaps still hamper the use of these biological inputs, particularly in arable farming systems. The aim of the workshop was to consider the conditions that would facilitate the integration of biosolutions into cropping systems and to identify the relevant indicators to be considered to ensure their widespread adoption. It has emerged that while biosolutions are considered to be innovations, they are complex in terms of how they work and how they are implemented. The challenge is to identify the best conditions for exploiting the potential of biosolutions, based in particular on field experiments such as the one carried out at the ARVALIS experimental station in Saint Hilaire en Woëvre, France. The effectiveness of these solutions, a key determinant of their adoption, depends on their rational use in combination with other agro-ecological levers. It has also become clear that if these solutions are to be adopted on a large scale, the evaluation of systems incorporating biosolutions must not be based solely on productivity indicators, but must also take into account all the 'co-benefits' associated with these solutions (multi-performance concept).
Les biosolutions qui comprennent les solutions de biocontrôle, les biostimulants et les biofertilisants sont considérées comme des leviers d’intérêt pour aider à la transition agroécologique des systèmes de production agricole et pour améliorer la résilience de ces systèmes face aux évolutions climatiques notamment. Cependant, un ensemble de freins d’ordre technique et socio-économique restreignent largement le recours à ces solutions, en particulier dans les systèmes de grandes cultures. L’atelier a eu pour objectifs de réfléchir aux conditions permettant de faciliter l’intégration des biosolutions dans les systèmes de culture et d’identifier les indicateurs pertinents à considérer pour assurer leur adoption à large échelle. Il ressort que si les biosolutions sont considérées comme des innovations, leur complexité en termes de mode d’action et de mise en œuvre nécessite d’identifier les conditions permettant l’expression de leur potentiel, en s’appuyant notamment sur des expériences « terrain » telle que celle mise en œuvre sur la station expérimentale ARVALIS de Saint Hilaire en Woëvre. L’efficacité de ces solutions, déterminant clé de leur adoption, est conditionnée par une utilisation raisonnée en combinaison avec d’autres leviers agroécologiques. Il ressort également que l’adoption des biosolutions à large échelle nécessite de sortir des schémas classiques d’évaluation basés sur des indicateurs de productivité pour prendre en compte l’ensemble des « co-bénéfices » associés à ces solutions (notion de multi- performance).
Origin : Publisher files allowed on an open archive
Licence : CC BY NC ND - Attribution - NonCommercial - NoDerivatives
