Unveiling the origins and transport processes of radioactive pollutants downstream from a former U-mine site using isotopic tracers and U-238 series disequilibrium - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Hazardous Materials Année : 2024
Pascale Blanchart
  • Fonction : Auteur
  • PersonId : 788413
  • IdRef : 164039481
High U concentrations (reaching up to 14,850 mg ⋅ kg−1), were determined in soils and sediments of a wetland downstream of a former U mine in France. This study aims to identify the origin of radioactive contaminants in the wetland by employing Pb isotope fingerprinting, (234U/238U) disequilibrium, SEM, and SIMS observations. Additionally, information about U and 226Ra transport processes was studied using U-238 series disequilibrium. The results of Pb fingerprinting highlighted inherited material inputs of different U-mines with mainly two types of U-ores: i) pitchblende (UO2), and ii) parsonsite (Pb2(UO2)(PO4)2). Moreover, significant disequilibrium of (230Th/238U) and (226Ra/230Th) activity ratios highlighted the mobility of 238U and 226Ra in the wetland, primarily driven by the water table fluctuations. Finally, this work uncovered a limitation of Pb isotope fingerprinting in the case of parsonsite materials, as the high natural Pb content of this mineral may hide the uranogenic Pb signature in the samples.
1-s2.0-S0304389424009956-main.pdf (8.65 Mo) Télécharger le fichier
Origine : Publication financée par une institution
Licence : CC BY - Paternité
hal-04574503 , version 1 (14-05-2024)
Paternité
Tingting Geng, Arnaud Mangeret, Olivier Péron, David Suhard, Josselin Gorny, et al.. Unveiling the origins and transport processes of radioactive pollutants downstream from a former U-mine site using isotopic tracers and U-238 series disequilibrium. Journal of Hazardous Materials, 2024, 472, pp.134416. ⟨10.1016/j.jhazmat.2024.134416⟩. ⟨hal-04574503⟩
0 Consultations
0 Téléchargements
