Spiritist delusions and spiritualism in the nosography of French psychiatry (1850-1950) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue History of Psychiatry Année : 2013
Délires spirites et spiritisme dans la nosographie de la psychiatrie française (1850-1950)
At the turn of the twentieth century there was a wave of delusions which had a direct link to spiritism in their form and content. These so-called spiritist or mediumistic delusions were the object of detailed study, and clinicians assigned them a place in nosography, especially in France. This work of classification was carried out as a function of the convictions and paradoxes that these delusions aroused; it also made it possible to question the relationship between pathology and belief. It is therefore important to emphasize certain ideological views of psychiatry on para-normality. We observed both a reductionist discourse concerning these domains, and at the same time their utilization in the construction of psychiatric knowledge.
Le Maléfan Evrard Alvarado - 2013 - Spiritist delusions and spiritualism in nosography.pdf (135 Ko) Télécharger le fichier
halshs-02137208 , version 1 (22-05-2019)
Pascal Le Maléfan, Renaud Evrard, Carlos S Alvarado. Spiritist delusions and spiritualism in the nosography of French psychiatry (1850-1950). History of Psychiatry, 2013, 24 (4), pp.477-491. ⟨10.1177/0957154X13503094⟩. ⟨halshs-02137208⟩
98 Consultations
188 Téléchargements
