Cluster correlation effects in $^{12}C$+$^{12}C$ and $^{14}N$+$^{10}B$ fusion-evaporation reactions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
L. Morelli
  • Fonction : Auteur
G. Baiocco
  • Fonction : Auteur
M. Bruno
  • Fonction : Auteur
M. Cinausero
  • Fonction : Auteur
M. Degerlier
  • Fonction : Auteur
D. Fabris
  • Fonction : Auteur
F. Gramegna
  • Fonction : Auteur
T. Marchi
  • Fonction : Auteur
S. Barlini
  • Fonction : Auteur
M. Bini
  • Fonction : Auteur
G. Casini
  • Fonction : Auteur
N. Gelli
  • Fonction : Auteur
A. Olmi
  • Fonction : Auteur
G. Pasquali
  • Fonction : Auteur
S. Piantelli
S. Valdré
  • Fonction : Auteur
The decay of highly excited states of 24Mg is studied in fusion evaporation events completely detected in charge in the reactions 12C+12C and 14N+10B at 95 and 80 MeV incident energy respectively. The comparison of light charged particles measured spectra with statistical model predictions suggests that the dominant reaction mechanism is compound nucleus (CN) formation and decay. However, in both reactions, a discrepancy with statistical expectations is found for α particles detected in coincidence with Carbon, Oxigen and Neon residues. The comparison between the two reactions shows that this discrepancy is only partly explained by an entrance channel effect. Evidence for cluster correlations in excited 24Mg CN is suggested by the comparison between the measured and calculated branching ratios for the channels involving α particles.
epjconf_ec2014_00026.pdf (130.44 Ko) Télécharger le fichier
in2p3-01188824 , version 1 (31-08-2015)
L. Morelli, G. Baiocco, F. Gulminelli, M. Bruno, M. Cinausero, et al.. Cluster correlation effects in $^{12}C$+$^{12}C$ and $^{14}N$+$^{10}B$ fusion-evaporation reactions. IWM-EC 2014 – International Workshop on Multi facets of EoS and Clustering, May 2014, Catania, Italy. pp.000026, ⟨10.1051/epjconf/20158800026⟩. ⟨in2p3-01188824⟩
47 Consultations
13 Téléchargements
