A System for Indian Postal Automation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
In this paper, we present a system towards Indian postal automation based on pin-code and city name information. In the proposed system, at first, non-text blocks (postal stamp, postal seal etc.) are detected and destination address block (DAB) is identified from the postal document. Next, lines and words of the DAB are segmented. Since India is a multi-lingual and multi-script country that was earlier colonized by UK, the address part may be written by combination of two scripts: Latin (English) and a local (state) script. Here we shall consider Bangla script (local state language) with English for recognition. It is very difficult to identify the script by which the pin-code portion is written. So we have used two-stage artificial neural network based general classifiers for the recognition of pin-code digits written in English/Bangla. To identify the script by which a word/city name is written, we propose a water reservoir based technique. Based on script identification result the city names on the corresponding script will be recognized. For recognition of city names we propose a NSHP-HMM (Non-Symmetric Half Plane-Hidden Markov Model) based technique. At present, the accuracy of the digit recognition module is 93.14% while that of city name recognition scheme is about 86.44%.
Fichier sous embargo
Date de visibilité indéterminée
inria-00000103 , version 1 (09-06-2005)
  • HAL Id : inria-00000103 , version 1
Kaushik Roy, Szilárd Vajda, Umapada Pal, Bidyut Baran Chaudhuri, Abdel Belaïd. A System for Indian Postal Automation. International Workshop on Document Analysis, Umapada Pal, Mar 2005, Kolkata, India. ⟨inria-00000103⟩
145 Consultations
0 Téléchargements
