The Euclidean Division Implemented with a Floating-Point Multiplication and a Floor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2005
This paper is a complement of the research report "The Euclidean division implemented with a floating-point division and a floor", RR-5604, INRIA, June 2005. Here we study conditions under which the floor of an exact product (or the Euclidean division, when the divisor can be known in advance) can be implemented using a floating-point multiplication followed by a floor function. The example of the Euclidean division by 3 is given.
intdiv-mul.pdf (135.37 Ko) Télécharger le fichier
inria-00000159 , version 1 (11-07-2005)
  • HAL Id : inria-00000159 , version 1
Vincent Lefèvre. The Euclidean Division Implemented with a Floating-Point Multiplication and a Floor. 2005. ⟨inria-00000159⟩
173 Consultations
68 Téléchargements
