HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Evocation and elaboration of solutions: Different types of problem-solving actions. An empirical study on the design of an aerospace artifact --- Evocation et élaboration de solutions : différents types d'actions de résolution de problème. Une étude empirique de la conception d'une structure aérospatiale
Willemien Visser 1
1 EIFFEL2 - Cognition and Cooperation in Design
Inria Paris-Rocquencourt, CNAM - Conservatoire National des Arts et Métiers [CNAM]
Résumé : An observational study was conducted on a professional designer working on a design project in aerospace industry. The protocol data were analyzed in order to gain insight into the actions the designer used for the development of a solution to the corresponding problem. Different processes are described: from the "simple" evocation of a solution existing in memory, to the elaboration of a "new" solution out of mnesic entities without any clear link to the current problem. Control is addressed in so far as it concerns the priority among the different types of development processes: the progression from evocation of a "standard" solution to elaboration of a "new" solution is supposed to correspond to the resulting order, that is, the one in which the designer's activity proceeds. Short discussions of * the double status of "problem" and "solution," * the problem/solution knowledge units in memory and their access, and * the different abstraction levels on which problem and solution representations are developed, are illustrated by the results. --- Des observations ont été conduites auprès d'un concepteur professionnel, pendant son travail sur un projet de conception dans l'industrie aérospatiale. Les données du protocole ont été analysées pour identifier les actions que le concepteur utilise pour développer une solution au problème posé. Différents processus sont décrits: de la "simple" évocation d'une solution qui pré-existe en mémoire jusqu'à l'élaboration d'une "nouvelle" solution à partir d'unités mnésiques sans aucun lien évident avec le problème en question. Le contrôle est abordé pour autant qu'il intervient dans la détermination de la priorité parmi les différents types de processus de développement de solution: on suppose que la progression qui va de l'évocation d'une solution "standard" à l'élaboration d'une "nouvelle" solution correspond à l'ordre qui en résulte, c'est-à-dire, l'ordre dans lequel l'activité du concepteur procède. De brèves discussions * du double statut de "problème" et de "solution," * des unités de connaissances concernant les problèmes et leurs solution(s) en mémoire et l'accès à ces connaissances, et * des différents niveaux d'abstraction auxquels des représentations de problème et de solution sont développées, reçoivent ensuite des illustrations dans la présentation des résultats
Document type :
Conference papers
Complete list of metadata
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/inria-00000165
Contributor : Willemien Visser Connect in order to contact the contributor
Submitted on : Thursday, November 30, 2006 - 5:46:20 PM
Last modification on : Monday, February 21, 2022 - 3:38:06 PM
Long-term archiving on: : Monday, September 20, 2010 - 4:52:11 PM
File
COGNITIVA_90_HAL.pdf
Publisher files allowed on an open archive
Identifiers
Collections
Citation
Willemien Visser. Evocation and elaboration of solutions: Different types of problem-solving actions. An empirical study on the design of an aerospace artifact --- Evocation et élaboration de solutions : différents types d'actions de résolution de problème. Une étude empirique de la conception d'une structure aérospatiale. COGNITIVA 90. At the crossroads of Artificial Intelligence, Cognitive science, and Neuroscience, AFCET (Association française pour la cybernétique économique et technique); Association COGNITIVA, Nov 1990, Madrid, Spain. pp.689-696. ⟨inria-00000165v2⟩
Share
Metrics
Record views
171
Files downloads
77
