Rethinking Language Models within the Framework of Dynamic Bayesian Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
We present a new approach for language modeling based on dynamic Bayesian networks. The philosophy behind this architecture is to learn from data the appropriate relations of dependency between the linguistic variables used in language modeling process. It is an original and coherent framework that processes words and classes in the same model. This approach leads to new data-driven language models capable of outperforming classical ones, sometimes with lower computational complexity. We present experiments on a small and medium corpora. The results show that this new technique is very promising and deserves further investigations.
RethinkingNotre (1).pdf (172.42 Ko) Télécharger le fichier
inria-00000449 , version 1 (21-11-2017)
  • HAL Id : inria-00000449 , version 1
Murat Deviren, Khalid Daoudi, Kamel Smaïli. Rethinking Language Models within the Framework of Dynamic Bayesian Networks. 18th Conference of the Canadian Society for Computational Studies of Intelligence, Canadian AI 2005, May 2005, Victoria, Canada. pp.432-437. ⟨inria-00000449⟩
50 Consultations
135 Téléchargements
