Fast genus 2 arithmetic based on Theta functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2005
In 1986, D. V. Chudnovsky and G. V. Chudnovsky proposed to use formulae coming from Theta functions for the arithmetic in Jacobians of genus 2 curves. We follow this idea and derive fast formulae for the scalar multiplication in the Kummer surface associated to a genus 2 curve, using a Montgomery ladder. Our formulae can be used to design very efficient genus 2 cryptosystems that should be faster than elliptic curve cryptosystems in some hardware configurations.
arithKsurf.pdf (171.27 Ko) Télécharger le fichier
inria-00000625 , version 1 (10-11-2005)
inria-00000625 , version 2 (20-08-2007)
  • HAL Id : inria-00000625 , version 1
Pierrick Gaudry. Fast genus 2 arithmetic based on Theta functions. 2005. ⟨inria-00000625v1⟩
285 Consultations
950 Téléchargements
