Abstract : This documentation stand for the design, implementation ideas and some features and capabilities added to the NETCONF Protocol through the BGP implementation process. Also, it explains a resulting library created for this implementation to transforms from the data device to the XML design and backward, that could be use for the implementation of new modules.
