BGP Module Documentation for the PYenca Agent - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2005
Radu State
  • Fonction : Auteur
  • PersonId : 755670
  • IdRef : 059893591
This documentation stand for the design, implementation ideas and some features and capabilities added to the NETCONF Protocol through the BGP implementation process. Also, it explains a resulting library created for this implementation to transforms from the data device to the XML design and backward, that could be use for the implementation of new modules.
BGP_Documentation.pdf (1.78 Mo) Télécharger le fichier
inria-00000803 , version 1 (20-11-2005)
  • HAL Id : inria-00000803 , version 1
Humberto Abdelnur, Radu State. BGP Module Documentation for the PYenca Agent. [Internship report] 2005, pp.57. ⟨inria-00000803⟩
55 Consultations
150 Téléchargements
