Individual GP: an Alternative Viewpoint for the Resolution of Complex Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
An unususal GP implementation is proposed, based on a more "economic" exploitation of the GP algorithm: the "individual" approach, where each individual of the population embodies a single function rather than a set of functions. The final solution is then a set of individuals. Examples are presented where results are obtained more rapidly than with the conventional approach, where all individuals of the final generation but one are discarded.
43_GP-467.pdf (241.62 Ko) Télécharger le fichier
inria-00000879 , version 1 (29-11-2005)
  • HAL Id : inria-00000879 , version 1
Pierre Collet, Evelyne Lutton, Frédéric Raynal, Marc Schoenauer. Individual GP: an Alternative Viewpoint for the Resolution of Complex Problems. GECCO, Genetic and Evolutionary Computation Conference,, Jul 1999, Orlando, Florida, USA. ⟨inria-00000879⟩
194 Consultations
127 Téléchargements
