Some Functions Computable with a Fused-mac - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Sylvie Boldo
Jean-Michel Muller
The fused multiply accumulate instruction (fused-mac) that is available on some current processors such as the Power PC or the Itanium eases some calculations. We give examples of some floating-point functions (such as ulp(x) or Nextafter(x,y)), or some useful tests, that are easily computable using a fused-mac. Then, we show that, with rounding to the nearest, the error of a fused-mac instruction is exactly representable as the sum of two floating-point numbers. We give an algorithm that computes that error.
ARITH17_Boldo.pdf (131.47 Ko) Télécharger le fichier
inria-00000895 , version 1 (01-12-2005)
  • HAL Id : inria-00000895 , version 1
Sylvie Boldo, Jean-Michel Muller. Some Functions Computable with a Fused-mac. 17th IEEE Symposium on Computer Arithmetic, Jun 2005, Cape Cod, Massachusetts, USA, pp.52-58. ⟨inria-00000895⟩
156 Consultations
261 Téléchargements
