Network Fusion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Network Fusion
Modular programming enjoys many well-known advantages but the composition of modular units may also lead to inefficient programs. In this paper, we propose an invasive composition method which strives to reconcile modularity and efficiency. Our technique, network fusion, automatically merges networks of interacting components into equivalent sequential programs. We provide the user with an expressive language to specify scheduling constraints which can be taken into account during network fusion. Fusion allows to replace internal communications by assignments and alleviates most time overhead. We present our approach in a generic and unified framework based on labeled transition systems, static analysis and transformation techniques.
APLAS04.pdf (342.21 Ko) Télécharger le fichier
inria-00000945 , version 1 (15-12-2005)
  • HAL Id : inria-00000945 , version 1
Pascal Fradet, Stéphane Hong Tuan Ha. Network Fusion. Asian Symposium on Programming Languages and Systems, Nov 2004, Taipei, Taiwan. ⟨inria-00000945⟩
119 Consultations
87 Téléchargements
