OntoBib: an Ontology-Based System for the Management of a bibliography - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Rim Alhulou
  • Fonction : Auteur
  • PersonId : 831790
Amedeo Napoli
Emmanuel Nauer
In this paper, we present our work aimed at improving retrieval and navigation services on bibliographic data. In this system, knowledge about the domain of documents (publications) is stored in an ontology, a formal model of conceptual knowledge. The ontology is employed to represent concepts and their relationships in order to carry out reasoning about documents. Reasoning helps researchers by providing more efficient document retrieval and navigation.
Nldb06.pdf (307 Ko) Télécharger le fichier
inria-00000972 , version 1 (09-01-2006)
  • HAL Id : inria-00000972 , version 1
Sahar D. Al-Sudani, Rim Alhulou, Amedeo Napoli, Emmanuel Nauer. OntoBib: an Ontology-Based System for the Management of a bibliography. [Research Report] 2006, pp.12. ⟨inria-00000972⟩
189 Consultations
220 Téléchargements
