GDS: An Architecture Proposal for a grid Data-Sharing Service - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Grid computing has recently emerged as a response to the growing demand for resources (processing power, storage, etc.) exhibited by scientific applications. We address the challenge of sharing large amounts of data on such infrastructures, typically consisting of a federation of node clusters. We claim that storing, accessing, updating and sharing such data should be considered by applications as an external service. We propose an architecture for such a service, whose goal is to provide transparent access to mutable data, while enhancing data persistence and consistency despite node disconnections or failures. Our approach leverages on weaving together previous results in the areas of distributed shared memory systems, peer-to-peer systems, and fault-tolerant systems.
AntBerCarDesBouJanMonSens05GDS.pdf (137.07 Ko) Télécharger le fichier
inria-00000983 , version 1 (09-01-2006)
Gabriel Antoniu, Luc Bougé, Mathieu Jan, Sébastien Monnet, Marin Bertier, et al.. GDS: An Architecture Proposal for a grid Data-Sharing Service. Workshop on Future Generation Grids, Nov 2004, Dagstuhl, Germany. pp.133-152, ⟨10.1007/978-0-387-29445-2_8⟩. ⟨inria-00000983⟩
1262 Consultations
357 Téléchargements
