How to bring together fault tolerance and data consistency to enable grid data sharing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Concurrency and Computation: Practice and Experience Année : 2006
This paper addresses the challenge of transparent data sharing within computing grids built as cluster federations. On such platforms, the availability of storage resources may change in a dynamic way, often due to hardware failures. We focus on the problem of handling the consistency of replicated data in the presence of failures. We propose a software architecture which decouples consistency management from fault tolerance management. We illustrate this architecture with a case study showing how to design a consistency protocol using fault-tolerant building blocks. As a proof of concept, we describe a prototype implementation of this protocol within JuxMem, a software experimental platform for grid data sharing, and we report on a preliminary experimental evaluation of the proposed approach.
Mots clés
cpe2004.pdf (472.53 Ko) Télécharger le fichier
inria-00000987 , version 1 (10-01-2006)
inria-00000987 , version 2 (11-01-2006)
  • HAL Id : inria-00000987 , version 1
Gabriel Antoniu, Jean-François Deverge, Sébastien Monnet. How to bring together fault tolerance and data consistency to enable grid data sharing. Concurrency and Computation: Practice and Experience, 2006, Concurrency and Computation: Practice and Experience, 17, pp.1-19. ⟨inria-00000987v1⟩
336 Consultations
295 Téléchargements
