Hierarchical Scheduling for Moldable Tasks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Pierre-François Dutot
The model of moldable task (MT) was introduced some years ago and has been proved to be an efficient way for implementing parallel applications. It considers a target application at a larger level of granularity than in other models (corresponding typically to numerical routines) where the tasks can themselves be executed in parallel on any number of processors. Clusters of SMP (symmetric Multi-Processors) are a cost effective alternative to parallel supercomputers. Such hierarchical clusters are parallel systems made from m SMP composed each by k identical processors. These architectures are more and more popular, however designing efficient software that take full advantage of such systems remains difficult. This work describes approximation algorithms for scheduling a set of tree precedence constrained moldable tasks for the minimization of the parallel execution time, with a scheme which is first used for two multi-processors and several bi-processors and then extended to the general case of any number of multi-processors. The best known approximation ratio for trees in the homogeneous case is 2.62, and although the hierarchical problem is harder our results are close as we obtain a ratio of 3.41 for two multi-processors, 3.73 for several bi-processors and 5.64 for the general case of several SMPs with a large number of processors. To our knowledge, this is the first work on precedence constrained moldable tasks on hierarchical platforms.
d_eurext05.pdf (148.34 Ko) Télécharger le fichier
inria-00001077 , version 1 (01-02-2006)
  • HAL Id : inria-00001077 , version 1
Pierre-François Dutot. Hierarchical Scheduling for Moldable Tasks. Euro-Par, Aug 2005, Lisbonne, Portugal, pp.302-311. ⟨inria-00001077⟩
191 Consultations
242 Téléchargements
