AP+SOMT: Agent-Programming Combined with Self-Organized Multi-Threading
In order to scale up processors beyond ILP, we explore the exploitation of coarser-grain parallelism. We advocate that a slightly different programming approach, called agent programming (AP), can unveil a large amount of parallelism, considerably simplify the task of optimizing compilers and empower the architecture with the ability to exploit potential parallelism based on available resources. We show that an SMT, augmented with dynamic steering strategies and thread swapping features, is an appropriate solution for such self-organized architectures; self-organized SMT is called SOMT. Using a set of specially written agent-like programs corresponding to classic algorithms, we show that AP+SOMT exhibit better performance, stability and scalability for a large array of data sets, and makes compiler optimizations less necessary. Finally, we outline that the approach can be progressively adopted as a combination of a hardware add-on and C language extensions, much like multimedia support in current superscalar processors.
