Constriction Computation using Surface Curvature - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
This paper provides a curvature-based algorithm to compute locally shortest geodesics on closed triangulated surfaces. These curves, which are called ``constrictions'', are useful for shape segmentation. The key idea of the algorithm is that constrictions are almost plane curves; it first finds well-located simple, plane, closed curves, and then slides them along the surface until a shortest geodesic is reached. An initial curve is defined as a connected component of the intersection between the surface and a plane going through an initial vertex. Initial vertices and planes are determined using approximations of surface curvature.
hetroy-electronic.pdf (9.66 Mo) Télécharger le fichier
inria-00001135 , version 1 (28-02-2006)
inria-00001135 , version 2 (18-01-2010)
  • HAL Id : inria-00001135 , version 1
Franck Hétroy. Constriction Computation using Surface Curvature. Eurographics (short paper), 2005, Dublin, Ireland, pp.1-4. ⟨inria-00001135v1⟩
262 Consultations
683 Téléchargements
