Automaton-based Non-interference Monitoring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2006
This report presents a non-interference monitoring mechanism for sequential programs. Non-interference is a property of the information flows of a program. It implies the respect of the confidentiality of the secret information manipulated. The approach taken uses an automaton based monitor. During the execution, abstractions of the events occurring are sent to the automaton. The automaton uses those inputs to track the information flows and to control the execution by forbidding or editing dangerous actions. The mechanism proposed is proved to be sound and more efficient than a type system similar to the historical one developed by Volpano, Smith and Irvine.
leguernic06automatonBasedNonInterferenceMonitoring.pdf (432.45 Ko) Télécharger le fichier
inria-00001221 , version 1 (10-04-2006)
inria-00001221 , version 2 (24-04-2006)
  • HAL Id : inria-00001221 , version 1
Gurvan Le Guernic, Anindya Banerjee, David Schmidt. Automaton-based Non-interference Monitoring. [Technical Report] KSU Report 2006-1, 2006, pp.49. ⟨inria-00001221v1⟩
101 Consultations
198 Téléchargements
