YAMS A fully Automatic Adaptive Isotropic Surface Remeshing Procedure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2001
Pascal Frey
  • Fonction : Auteur
  • PersonId : 1108560
  • IdRef : 133850471
This technical note describes the main features of YAMS {This software was registered with the APP under n° IDDN.FR.001.410006.00.R.P. 1999.000.20600 on october 4, 1999.}, an automatic adaptive surface remeshing tool. The aim of the software, the input and output files and the list of error messages are defined in this document. A number of typical application examples are provided to explain the various possibilities of the code. Finally, a short technical description of the algorithm and the various ways to obtain the software are given. YAMS has been developed within the GAMMA research project at INRIA­Rocquen­court. This document describes the features of the current version : V2.1 (June, 2001).
Autre [cs.OH]
RT-0252.pdf (3.23 Mo) Télécharger le fichier
inria-00069922 , version 1 (19-05-2006)
  • HAL Id : inria-00069922 , version 1
Pascal Frey. YAMS A fully Automatic Adaptive Isotropic Surface Remeshing Procedure. RT-0252, INRIA. 2001, pp.36. ⟨inria-00069922⟩
718 Consultations
689 Téléchargements
