Triplet : a Clustering Scheduling Algorithm for Heterogeneous Platforms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2001
In this report we present a new scheduling algorithm for heterogeneous plate-forms. It uses the clustering techniques and has a better behavior than the HEFT algorithm in most of the cases.
Autre [cs.OH]
RT-0248.pdf (212.79 Ko) Télécharger le fichier
inria-00069926 , version 1 (19-05-2006)
  • HAL Id : inria-00069926 , version 1
Bertrand Cirou, Emmanuel Jeannot. Triplet : a Clustering Scheduling Algorithm for Heterogeneous Platforms. [Technical Report] RT-0248, INRIA. 2001, pp.11. ⟨inria-00069926⟩
98 Consultations
213 Téléchargements
