Uplink dynamic discrete power control in cellular networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2006
Konstantin Avrachenkov
Gregory Miller
  • Fonction : Auteur
Balakrishna Prabhu
We consider an uplink power control problem where each mobile wishes to maximize its throughput (which depends on the transmission powers of all mobiles) but has a constraint on the average power consumption. A finite number of power levels are available to each mobile. The decision of a mobile to select a particular power level may depend on its channel state. We consider two frameworks concerning the state information of the channels of other mobiles: (i) the case of full state information and (ii) the case of local state information. We consider both cooperative as well as non-cooperative power control. We manage to characterize the structure of equilibria policies and, more generally, of best-response policies in the non-cooperative case. We present an algorithm to compute equilibria policies in the case of two non-cooperative players. Finally, we study the case where a malicious mobile, which also has average power constraints, tries to jam the communication of another mobile. Our results are illustrated and validated through various numerical examples.
Autre [cs.OH]
RR-5818.pdf (277.64 Ko) Télécharger le fichier
inria-00070207 , version 1 (19-05-2006)
inria-00070207 , version 2 (15-12-2006)
  • HAL Id : inria-00070207 , version 1
Eitan Altman, Konstantin Avrachenkov, Gregory Miller, Balakrishna Prabhu. Uplink dynamic discrete power control in cellular networks. RR-5818, 2006, pp.31. ⟨inria-00070207v1⟩
Collections
INRIA-RRRT
222 Consultations
168 Téléchargements
