Formal QoS Validation Approach on a Real-Time MAC Protocol for Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2005
Thomas Watteyne
Isabelle Augé-Blum
  • Fonction : Auteur
Stéphane Ubéda
Several wireless sensor network applications are currently popping up, in various domains. Their goal is often to monitor a geographic area. When a sensor detects a monitored event, it informs a sink node using alarm messages. The area surveillance application needs to react to such an event with a finite, bounded and known delay: these are real-time constraints. The network being linear, routing becomes unnecessary. This work proposes a new real-time MAC protocol with realistic assumptions on sensor networks. We present a formal validation of this protocol, and explicit the worst case times for the services offered by the protocol (initialization and alarm transmission using different modes).
RR-5782.pdf (521.4 Ko) Télécharger le fichier
inria-00070239 , version 1 (19-05-2006)
  • HAL Id : inria-00070239 , version 1
Thomas Watteyne, Isabelle Augé-Blum, Stéphane Ubéda. Formal QoS Validation Approach on a Real-Time MAC Protocol for Wireless Sensor Networks. RR-5782, INRIA. 2005, pp.16. ⟨inria-00070239⟩
184 Consultations
303 Téléchargements
