A PCC Architecture based on Certified Abstract Interpretation
Proof Carrying Code (PCC) is a technique for downloading mobile code on a host machine while ensuring that the code adheres to the host's security policy. We show how certified abstract interpretation can be used to build a PCC architecture where the code producer can produce program certificates automatically. Code consumers use proof checkers derived from certified analysers to check certificates. Proof checkers carry their own correctness proofs and accepting a new proof checker amounts to type checking the checker in Coq. The checking of certificates is accelerated by a technique for (post-)fixpoint compression. The PCC architecture has been evaluated experimentally on a byte code language for which we have designed an interval analysis that allows to generate certificates ascertaining that no array-out-of-bounds accesses will occur.
