DGTD methods using modal basis functions and symplectic local time-stepping: application to wave propagation problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
The Discontinuous Galerkin Time Domain (DGTD) methods are now widely used for the solution of wave propagation problems. Able to deal with unstructured meshes past complex geometries, they remain fully explicit with easy parallelization and extension to high orders of accuracy. Still, modal or nodal local basis functions have to be chosen carefully to obtain actual numerical accuracy. Concerning time discretization, explicit non-dissipative energy-preserving time-schemes exist, but their stability limit remains linked to the smallest element size in the mesh. Symplectic algorithms, based on local-time stepping or local implicit scheme formulations, can lead to dramatic reductions of computational time, which is shown here on two-dimensional acoustics problems.
RR-5749.pdf (1.22 Mo) Télécharger le fichier
inria-00070270 , version 1 (19-05-2006)
  • HAL Id : inria-00070270 , version 1
Serge Piperno. DGTD methods using modal basis functions and symplectic local time-stepping: application to wave propagation problems. [Research Report] RR-5749, INRIA. 2005, pp.31. ⟨inria-00070270⟩
109 Consultations
436 Téléchargements
