Simple Seed Architectures for Reciprocal and Square Root Reciprocal - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2005
Jean-Michel Muller
Arnaud Tisserand
This report presents a simple hardware architecture for computing the seed values for reciprocal and square root reciprocal. These seeds are used in the initialization of floating-point division and square root software iterations. The proposed solution is based on polynomial approximation with specific coefficients and a table lookup. The obtained architectures lead to small and fast circuits.
RR-5720.pdf (337.45 Ko) Télécharger le fichier
inria-00070298 , version 1 (19-05-2006)
  • HAL Id : inria-00070298 , version 1
Milos Ercegovac, Jean-Michel Muller, Arnaud Tisserand. Simple Seed Architectures for Reciprocal and Square Root Reciprocal. RR-5720, INRIA. 2005, pp.25. ⟨inria-00070298⟩
100 Consultations
576 Téléchargements
