Reporting maximal cliques: new insights into an old problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Frédéric Cazals
C. Karande
  • Fonction : Auteur
Reporting maximal cliques of a graph is a fundamental problem arising many areas. Surprisingly, this problem is often tackled resorting to the old Bron-Kerbosch algorithm (1973; denoted BK), or its recent variant by I. Koch (2001; denoted ). Both algorithms suffer from a poor output sensitivity and worst-cases. In this context, this paper makes three contributions. First, we show that a slight modification of the greedy pivoting strategy used by I. Koch allows one to get rid of worst-cases, also improving overall performances. Second, exploiting the recursive structure of non maximal cliques, we show the pivoting strategy developed by I. Koch is a particular case of a more general optimization strategy based on the concept of dominated nodes. Using different instantitations of this concept, we design four Modified BK algorithms, with better output-sensitivity. Third, we discuss implementation issues and provide a detailed experimental study on random graphs. The bottomline of this study is the investigation of the trade-off between output sensitivity and the overhead associated to the identification of dominated nodes.
Autre [cs.OH]
RR-5615.pdf (237.82 Ko) Télécharger le fichier
inria-00070393 , version 1 (19-05-2006)
inria-00070393 , version 2 (30-01-2007)
  • HAL Id : inria-00070393 , version 1
Frédéric Cazals, C. Karande. Reporting maximal cliques: new insights into an old problem. [Research Report] RR-5615, 2006, pp.25. ⟨inria-00070393v1⟩
Collections
INRIA-RRRT
135 Consultations
1083 Téléchargements
