Correctly Rounded Newton-Cotes Quadrature - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Numerical integration is an important operation for scientific computations. Although the different quadrature methods have been well studied from a mathematical point of view, the analysis of the actual error when performing the quadrature on a computer is often neglected. This step is however required for certified arithmetics. We study the Newton-Cotes quadrature scheme and give enough details on the algorithms and the error bounds to enable software developers to write a correctly-rounded Newton-Cotes quadrature.
Autre [cs.OH]
RR-5605.pdf (291.91 Ko) Télécharger le fichier
inria-00070402 , version 1 (19-05-2006)
  • HAL Id : inria-00070402 , version 1
Laurent Fousse. Correctly Rounded Newton-Cotes Quadrature. [Research Report] RR-5605, INRIA. 2005, pp.20. ⟨inria-00070402⟩
49 Consultations
301 Téléchargements
