Convergence of an Adaptive Scheme for the one dimensional Vlasov-Poisson system - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports (Research Report) Year : 2005
An adaptive semi-Lagrangian scheme for solving the Cauchy problem associated to the periodic one-dimensional Vlasov-Poisson system is proposed and analyzed. A key feature of our method is the accurate evolution of the adaptive mesh from one time step to the next one, based on the analysis of the local regularity and how it gets transported by the numerical flow. The accuracy of the scheme is monitored by a prescribed tolerance parameter which represents the local interpolation error at each time step.The numerical solutions are proved to converge in sup-norm towards the exact ones as the toloerance parameter and the time step tend to zero provided the initial data is Lipschitz and has a finite total curvature. t)$, Several numerical tests illustrate the effectiveness of our approach for generating the optimal adaptive discretizations.
RR-5519.pdf (633.39 Ko) Télécharger le fichier
Dates and versions
inria-00070487 , version 1 (19-05-2006)
Identifiers
  • HAL Id : inria-00070487 , version 1
Cite
Martin Campos Pinto, Michel Mehrenberger. Convergence of an Adaptive Scheme for the one dimensional Vlasov-Poisson system. [Research Report] RR-5519, INRIA. 2005, pp.49. ⟨inria-00070487⟩
251 View
110 Download
Share
