Enabling JXTA for High Performance Grid Computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Grid computing has recently emerged as a response to the growing demand for resources (processing power, storage, etc.) exhibited by scientific applications. However, as grid sizes increase, the need for self-organization and dynamic reconfigurations is becoming more and more important. Since such properties are exhibited by P2P systems, the convergence of grid computing and P2P computing seems natural. However, using P2P systems (usually running on the Internet) on a grid infrastructure (generally available as a federation of SAN-based clusters interconnected by high-bandwidth WANs) may raise the issue of the adequacy of the P2P communication mechanisms. This paper evaluates the communication performance of the JXTA P2P library over SANs and WANs, for both J2SE and C bindings. We analyze these results and we evaluate solutions able to improve the performance of JXTA on such grid infrastructures.
Autre [cs.OH]
RR-5488.pdf (122.22 Ko) Télécharger le fichier
inria-00070519 , version 1 (19-05-2006)
  • HAL Id : inria-00070519 , version 1
Gabriel Antoniu, Mathieu Jan, David A. Noblet. Enabling JXTA for High Performance Grid Computing. [Research Report] RR-5488, INRIA. 2005, pp.14. ⟨inria-00070519⟩
173 Consultations
111 Téléchargements
